quick pump swap Q.
Old 12-17-2012, 11:12 PM
Greg5OH's Avatar
Greg5OH
Greg5OH is offline
quick pump swap Q.
currently nothing is off my engine. I have a spare pump i would like to put on but it was removed with the timing gear. can i unbolt my old pump the proper way and simply bolt up my new pump??
Old 12-18-2012, 12:24 AM
38Chevy454's Avatar
38Chevy454
38Chevy454 is offline
Yes, just unbolt the new pump form the timing gear and swap it in. Same as if you had a new pump without the gear attached. You need a 12-point to get the bolts loose.
Old 12-18-2012, 12:51 AM
Greg5OH's Avatar
Greg5OH
Greg5OH is offline
10 mil is it?
Old 12-18-2012, 12:59 AM
tecgod13's Avatar
tecgod13
tecgod13 is offline
Either 10 mm or 3/8" I can't remember which, but since you have a pump out, its pretty easy to test both and whichever fits tightest.
Old 12-18-2012, 01:07 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
take pics. anyone swap with the lines still on the pump? i did my pump a few years ago and dont remember.
Old 12-18-2012, 06:28 AM
Greg5OH's Avatar
Greg5OH
Greg5OH is offline
^i watched a video of a guy do that, but he pulled the pump with the cover. To keep it aligned it took the oil fill neck off and marked the internal part against the gear cover. U know if your off if your marks dont line up!
Eallend7
08-14-2013 04:01 PM
daleyboy
03-18-2013 10:53 AM
mel F350
05-21-2005 09:32 PM
kcpete
05-26-2004 02:45 PM
Quick Reply: quick pump swap Q.
