flywheel rubbin block plate
ive got a 90 302 out of a ltd mated to a c4 with the small bellhousing so i used a tci flywheel with 157 teeth and 50 ounce balance im having a problem with the wait on the flywheel rubbing the starter housing and the block plate i've ordered a set of flywheel spacers from summit hoppig to fix this problem ,wondering if anyone else has had a problem like this, the trans was in the truck bolted to a 240 i used the same block plate and starter
Brian460
18
10-15-2023 09:00 PM
rangerottis
05-23-2014 03:57 PM
mh822
02-19-2006 04:56 PM
