speedo repair ?
Old 12-13-2012, 07:55 PM
thomc's Avatar
thomc
thomc is offline
speedo repair ?
My new speedo cable went nuts today and the needle began jumping wildly. Before I could pull over and disconnect the cable the needle came off and fell down inside the speedometer.I have not yet taken it apart to check it out. If the needle just popped off the shaft might I be able to put the needle back on? Does the shaft return to 0 mph when that happens? Or does it get out of sync? Any hope for my speedometer?
Old 12-14-2012, 08:19 AM
raytasch's Avatar
raytasch
raytasch is online now
Believe Nothing
Your speedometer has probably suffered from cold weather lubrication problems. I have successfully repaired mechanical proofmeters on tractors by reattaching the needle to the post. Your speedometer may or may not have suffered more damage than loss of the indicating needle. BTW, a proofmeter is a tachometer and hour meter .
Old 12-14-2012, 02:05 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Search on United Speedometer Service, they offer repair service.
It would help if you put your truck's year and model in your signature. '51 - '52 speedos are widely available new because they were used in parcel trucks up into the '60's.
Old 01-09-2013, 04:28 PM
mll1446's Avatar
mll1446
mll1446 is offline
Had same thing happen on a 53 f 100
How do you repair this when happens on a 53 f100
52 F1 Stocker
10-21-2015 08:20 AM
alconk
04-18-2009 11:33 PM
natron343
12-14-2004 11:07 AM
nudgey
01-05-2004 05:31 PM
Bogaski
16
12-12-2001 02:00 PM
Quick Reply: speedo repair ?
