Are they better heads? Bigger valves, runners, or port work? What did they come off of? If so there could be a gain in power, but a set of conversion bolts would be needed the come with top hat type sleeves. The 351W heads have larger bolt hole than the 302 and the sleeves take-up the space. I have used them and have an old set.
If the heads are from the same year,and a few years earlier and later,they are the same head,so no real benefit unless something is wrong with your 302 heads.
