Problems aligning running boards-pics
I'm going to guess that's not the original bed. I had the same problem when I bought a bed from a 57 and newer truck. Ford moved the fender mounting bolts up on the newer beds.
Other folks have had the same problem: running-board-help
Could I just get a fender patch and add it on to the current fender so it will meet the running board?
Mid Fifty F-100 Parts - Fender Patch Panel, Rear, Left 6" At Run Board
Also, why does my running board tilt from front to back?
It shouldn't. The front and rear running board supports should hold the board at the same level. If they don't, I'm guessing something is bent, installed wrong, or the rear support is from a larger truck.
Here is the normal installation. (not my truck)
PWHerman
20
06-05-2018 03:01 PM
my1954fordf100
23
02-28-2018 10:14 PM
EAK69
05-23-2013 12:55 AM
