Drive train shutter/vibration
I have an 07' F250 superduty 6.0 crew cab Lariat. I have had a shutter and vibration in my drive train for a couple of years now and I am sick of trying to track it down. Hope you guys can give some input or direction.
Symptoms: From a start the truck is smooth up to 40 mph. At 40mph a shake/shutter/vibration kicks in and is there up to 62 MPH. After that it smoothes out but then vibrates again between 75-80 mph. Also, when pulling a trailer I will get a bad shutter from take off. The vibration in the drive train comes from under the driver seat and back. I get no vibration or shake in the steering wheel.
Things I've done: Removed drive shaft and greased slip yolk. Drove truck with no rear drive shaft used front wheels to pull it down the road. All viration and shake gone. Took drive shaft to drive line shop all u-joints replaced and new carrier bearing installed. Shutter and vibration better but not gone. Just had trans overhauled last week due to a delayed reverse engagement. Installed a brand new complete driveshaft assembly from ford. Still have shutter/vibration between 40-62mph when accelerating and when coasting to a stop. High speed vibrations are still there also. A $2300.00 trans overhaul, a $1000.00 driveshaft assembly, and I even tried new tires a while back at $1400.00 and no change. Any input or direction would be great as this viration is getting to be damn expensive. Anybody had issues with the rear diff or the transfer case causing similar symptoms? These are the only two things in the drive line that haven't been relaced or overhauled.
on
I've had an audible occasional frame resonance noise only while under load since the truck was new, like a vibration you cannot feel if that makes sense. I've always figured that it was because its a fairly heavy duty truck and an XL which doesnt give much cab isolation. 92k and it doesnt manifest itself beyond the occasional annoying noise. When I installed my seats and tunes I dynamatted all the sheet metal but I still hear it.
A "yummyummyumm" kind of vibration in the 2-3k~hz frequency is drive train. A jiggling vibration can be suspension or tires. I had the dreaded driveline vibe in my last two 4x2 Rams. Dodge finally gave up and I came back to Ford. Problem solved. However, I've never had good luck with tire shops being able to balance tires. It must be rocket science or something beyond what $8 an hour will buy. Michelins have given me the best ride while Continentals seem to be made in egg shaped molds. I get a bounce from 45-50mph and then again from 75- to around 180mph.
Vibration
Had a something simular going on with my 04 F-350. Mine is four wheel drive and after doing many different things finally the older owner of a local tire shop checked my rims and found that three of them where out of round. Replaced the rims and vibration stopped.
Last edited by ballpark838; 12-09-2012 at 09:28 AM. Reason: needed more info in post
Dines78,
Are you the original owner ? Looked under the truck near the tail shaft/transferee case
for a big counter weight. If it's not there you may be one of the trucks that need it.
It is there to stop some harmonics from the drive train. People have been known to
remove then thinking that they are not needed and have not had problems and some
have had problems and some don't have it and need it.
Also while your under there check the drive line to see that it is straight line from the
flange to the rear differential. In other words check the center bearing to hake sure
it did not get offset somehow.
Sean
Sean
Thanks for the replies. Yes, I have owned this money pit since new. I do have the large counter wieght on my drive shaft but have exhausted the possilbiity that the drive shaft is causing my problem. The original drive shaft had same symptoms, original shaft rebuilt and balanced had same symptoms, a used shaft I installed had same symptoms, and a new complete shaft assembly from Ford is producing the same symptoms. I would think if it was shaft alignment or balance I would get some kind of change.
On another note, this is the most expensive vehicle I had ever purchased at $52,0000.00 and it has been the biggest piece of crap I have ever owned. After more than 15 times into the dealer for warranty repairs and then out of pocket repairs that an expired warranty doesn't cover I contacted Ford to discuss what they were going to do to regain my faith in them. They offered me $500.00 cash back on one of their new $60,0000.00 trucks with the 6.7 diesel. I'm guessing that was suppose to be a joke because I'm sure as hell not going to by another hunk of **** from them after this truck.
