ABS light after changing rear
Old 12-01-2012, 07:05 PM
fatforty's Avatar
fatforty
fatforty is offline
I have a 2002 Explorer that had a whining rear, changed it out with a good rear out of my parts truck and now I have an ABS light on. It says something about input to the sensor and output from the sensor and left and right wheels. 4 Codes in all. I changed the speed sensor in the top of the rear to the one that was in this truck because the light wasn't on before and it still has this light. Any ideas? Thanks, John
Old 12-01-2012, 08:53 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is online now
when you turn the key on and start the truck, the abs light comes on for a few seconds, the then runs a continuity test to the front two ABS and the one rear ABS sensors. If all are connected and have continuity, the light goes out.... After you put the truck in gear and start moving, maybe 5 MPH, the computer runs a comparison test to see that all sensors read about the same speed. If one is bad, the light comes back on.... I once changed a front hub and when pushing the plastic plug connector back together i got it cocked and smashed on of the two prongs inside the plug. You might check that on the rear.
RLTotten
1997 - 2003 F150
11-15-2012 03:07 AM
peter p
1997 - 2003 F150
01-25-2010 10:26 AM
pitrow
1997-2006 Expedition & Navigator
02-19-2008 01:39 PM
dogman
02-28-2006 06:01 PM
dieselhappy
11-20-2004 07:17 PM
Quick Reply: ABS light after changing rear
