lokar throttle cable??
Another question to an item that I may have to use..if u don't already know..I'm converting my engine from a blown block 360 to a rebuilt 40000 mile ago 300/6. I have the offy c intake and running an edelbrock.now..how the world do I hook a throttle cable/linkage to the carb. I hear some guys get a cable from lokar? Just curious how to do this and the best way to go about it.
some quick thoughts
I just finished an install on my 300-6. I was able to use the stock throttle cable for the YFA actually. I was able to take a standard Ford throttle cable bracket from an 84-85 Ranger/Brocno II (with a 2.8 carbed motor), and bolted it to the provided 4/2 barrel adapter that I got From Clifford.
I just added (welded) a small piece of aluminum stock to the adapter and drilled and tapped it for the bracket bolts....
Ford Truck Enthusiasts Forums - JohnSmith3524's Album: Current Projects - Picture
Works great...Good luck
I should've noticed your issue when i read it..I like the older style throttle arrangement. I can understand the dilemma now. I'm sure some here will have some input. Maybe some sort of hybrid /bellcrank/cable mod would do....?
If your referring to the ball on the end of the pedal arm that hooked to the bell crank setup you can drill it out its just pressed in so it'll come out then rig a bracket off of one of the studs that hold the intake/exhaust on. I originally set it up with the cable off of a 10 speed bike but it was hanging up so I eventually broke down and bought a lokar.
The pedal travel is adjustable via the cable itself it has anchor points that allow you to take up slack. Lokar TC1000U36 - Lokar Throttle Cables - Overview - SummitRacing.com was the one I used, I run a DP intake though so my cable goes up and wraps around the carb pulling towards the passenger side fender.
yozsi
23
01-29-2005 12:36 AM
tripnosis
08-13-2003 06:17 PM
aunchman
20
09-05-2002 02:39 PM
