1986 ford f150
It could be your TPS (Throttle Position Sensor) on the early EFI systems they are real touchy on adjustment. The only adjustment is the idle stop screw and it has to be set to 1.0 volt measured at the center lead. If you can't get it there, then it will need replacing. Do not use an aftermarket, only a Motorcraft one will work correctly!
This might help:
Fuel Injection Technical Library » Throttle Position Sensor (TPS)
If you're interested in seeing what the computer has to say:
Fuel Injection Technical Library » How To Run a Self-Test
XRayAlpha
27
02-11-2018 02:48 PM
DieselCamper
03-24-2017 08:24 PM
1986OhioF150
01-28-2015 08:58 PM
croman2
09-27-2004 12:06 PM
