Bulbs!
Bulbs!
First off, when you need info on your vehicle, you should mention the year and model. They aren't all the same.
If you have an owner's manual, the bulb listing should be in there, or,
Your local parts store should have an application catalog next to the bulb display.
http://easyad.net/images/94vanavitar.jpg http://www.easyad.net/images/mustang1.gif
'94 E-150 Conversion Van 4.9 / C-6 -- '89 Mustang LX 5.0
Bulbs!
If it's like the parking light bulbs - which I believe it is, follow the wiring into the hole in the fender. Get a set of long needle-nose, or other, pliers, and reach in there, twist, and pull the plastic bulb base out. Change the bulb and do the opposite to put it back. It is a bit of a hassle, but the lens probably does not need to come off.
Bulbs!
I've never replaced just the turn signal lamp cover itself, however to remove the bezel, remove the top two screws, and there is two lower bolts about half-way down between the radiator tank/washer resevoir and the radiator front support.
Removing it will make light replacement very simple. I would recommend replacing both sets on each signal, b/c it won't be long before the other lamp will go out.
'93 F-150 loaded and modified!
Check my Gallery
AllaboutMPG
Electrical Systems/Wiring
07-31-2014 08:21 PM
atomicjoe23
25
02-26-2009 08:28 PM
