Heater core
Old 11-11-2012, 12:07 PM
KJLYPW's Avatar
KJLYPW
KJLYPW is offline
Heater core
3 door heater in my 48 F-68, Canadian built truck. Heater core leaking a bit, so pulled it apart, took off one of the tanks, sure enough full of crud. Will try cleaning cores out, but pretty sure by the time thats done all the buried corrosion under the crud, it will leak a lot more.
Any ideas if anyone makes an aftermarket replacement core, or has a good used core. Alternatively, once I get it cleaned out anyone know of a good "mechanic in a can" product to try and plug up the leaks- heater core only, wont put it in the engine.
Old 11-19-2012, 03:23 PM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
Crud does not necessarily translate into leaks but if you do have some:
Old 11-19-2012, 03:42 PM
Doc's Avatar
Doc
Doc is offline
Just about any reputable radiator repair shop can repair your core if it's not just completely disentegrated. I paid ten bucks to have mine repaired shortly after I got my truck.
Old 11-19-2012, 04:57 PM
Wayne Waldrep's Avatar
Wayne Waldrep
Wayne Waldrep is offline
i have the exact same unit. must have been popular at the time.
Old 12-24-2012, 03:42 PM
Brian Cleary's Avatar
Brian Cleary
Brian Cleary is offline
This is the same heater I have in my 49 F47 except yours is MUCH nicer than mine
A rad shop can check the core out and repair it as required. Might be worth a shot.
Brian
Old 12-24-2012, 07:30 PM
Greg M-47's Avatar
Greg M-47
Greg M-47 is offline
That seems to be a very common heater in the Canadian trucks. I have one just like it in my 1949 M-47. I've seen lots of them over the years at the swapmeets here in Ontario.
I got mine recored years ago at a rad shop. Wasn't a lot of money to have it done.
Greg -47
Old 12-26-2012, 09:36 AM
Project-55's Avatar
Project-55
Project-55 is offline
If you want to "boil" out the crud in your core I would use Super Clean. Fill you unit 1/2 to 3/4 full then cap off the ports and let it set for a day or so, shake it once in a while and flip it from side to side occasionally.
Drain and flush with hot water and repeat again.
Super Clean works well for heavy cleaning operations but its tough on your skin and the fumes make me gag, but it does work great.
Old 12-26-2012, 03:18 PM
tip49's Avatar
tip49
tip49 is offline
Same core
I have the same heater; had local rad shop flush and then seal leaks.
I also re-routed the "plumbing" of the feed copper lines to exit horizontally through the firewall to connect to my heater hoses on my 5.0L
Tom
Old 12-26-2012, 04:12 PM
oldmerc's Avatar
oldmerc
oldmerc is offline
oldmerc
I had the same one in my M68 . I would be willing to part with the core . Send me a PM
Old 12-26-2012, 10:44 PM
fifty-two_f1's Avatar
fifty-two_f1
fifty-two_f1 is offline
Those are not aftermarket heaters. Those were the standard heater for the 48-50 trucks. That is the heater you got if you wanted a heater but didnt want to pay for the fresh air set up. The actual core has the same dimensions as the 41-48 car and has the same exact motor as the car. it is a reversible motor that has 4 wires coming out of it. All of those heaters also had a drain plug in the core. The trucks used almost the same switch as the car but instead of saying "indirect/direct" it said "defrost/heat" and the brackets look the same but the trucks switch and defroster cable are backwards from the car..
Old 12-27-2012, 05:20 AM
Wayne Waldrep
good info fifty- two. now if i can just get mine to spin slower (12v now) ill have a nice setup..... oh yeah, and some ducting!
Old 12-27-2012, 03:59 PM
Greg M-47's Avatar
Greg M-47
Thanks fifty two. I thought they were standard equipment as they seemed so plentiful on the trucks up here.
Greg M-47
Old 12-27-2012, 07:03 PM
Mervy49's Avatar
Mervy49
Mervy49 is offline
I was wondering about that. I ran my 6 volt heater motor on the bench with 12 volts and it seemed to run real good for quite a while and didn't heat up, or is it doomed?
Old 12-27-2012, 07:32 PM
Wayne Waldrep
well mine spins at what seems like waaayyy too fast. i haven't fooled with it much yet.
Old 12-28-2012, 11:08 AM
tip49's Avatar
tip49
tip49 is offline
Aftermarket switch
I used an after market 12 volt fan motor, so no issues with speed but..
could you put a rheostat (control switch) in power line to control the fan speed by increasing the line resistance (dropping volt ) if staying with 6 volt fan ?
Tom
Quick Reply: Heater core
