accelerator sticking
Old 09-08-2014, 06:55 AM
myutesux's Avatar
myutesux
myutesux is offline
Hi all just need some help my accelerator is sticking and getting a bit dangerous foot pedal is not returning needing to lift back with foot I have tried WD 40 is their anything that will fix this from happening
Old 09-08-2014, 09:37 AM
Harte3's Avatar
Harte3
Harte3 is offline
A stiff return spring might help...but that doesn't necessarily address why it is sticking.
Old 09-08-2014, 10:59 AM
ZarK-eh's Avatar
ZarK-eh
ZarK-eh is offline
I would pull the parts and clean them up. Take the cable and oil one end and hang it until oil seeps out the bottom. What kinda oil? *shurgs* but I used synthetic engine oil or whatever I had around.
Pulling the pedal assembly and cable should make it obvious where the sticky is and oiling anyway should help it last.
Old 09-08-2014, 12:44 PM
1986F150six's Avatar
1986F150six
1986F150six is offline
Disconnect the throttle cable from the carburetor and then move the throttle arm to see if the carburetor is sticking. This will eliminate the cable.
Check to see if the carburetor housing is worn where the throttle plate/shaft exits the body. If much free play is evident, the throttle plate might be rubbing the inside if the throttle body causing binding.
pnp522
1983 - 2012 Ranger & B-Series
02-26-2019 06:55 AM
big64
04-14-2009 09:05 PM
runner
13
10-06-2006 04:15 PM
water 5
22
04-06-2006 09:53 PM
topohill
1997-2006 Expedition & Navigator
11-09-2004 09:09 PM
Quick Reply: accelerator sticking
