Manual Trans Swap 5.8L?
Old 10-29-2012, 02:54 PM
Bikedude987's Avatar
Bikedude987
Bikedude987 is offline
I've got a f150 custom 4x4 wiht a 5.8 and e4OD. Regardless of the trans's health, I'm interested in swapping in a manual. What transmission would be a good candidate?
I have a wrecked 5.0 manual truck that I could steal things like the master cylinder and shifter off of (maybe) so anything that transfers over between the two would be great.
What all is involved parts wise?
Old 10-29-2012, 04:01 PM
preppypyro's Avatar
preppypyro
preppypyro is offline
Basically its everything you would think it is, from the pedal assembly, to the flywheel, but the only thing im not sure of is if your transfer case is the same as the zf-5.
Oh yeah, you probably want the zf-5 for your 351. I have had a few 302's with the m5od and have had great luck with them, but for the larger engine (especially if you run more power then stock) you probably want the stouter transmission.
Old 10-29-2012, 04:12 PM
jas88's Avatar
jas88
jas88 is offline
The xfer case is the same for the ZF5 and the M5OD and the E4OD - they all use the BW1356 and it bolts up to all of them.
Old 10-29-2012, 04:38 PM
blue 92's Avatar
blue 92
blue 92 is offline
actually, there also is the bw 4407,which came with the zf5 i swapped into my truck. however, the original bw 1356 bolts right to it, linkage and all, this is what i did for the time being. once i have the time and cash to get a new fixed yoke rear driveshaft, the much beefier looking 4407 will be reunited with the zf. by the way, i went from a 300 m5od to a 351 zf, both driveshafts fit right in with the 1356, no changes necessary. same with the transmission/t-case crossmember. since my truck always was a 5 speed, i cant help you with the pedals and stuff. hope this helps.
Fleury_XLT
10-04-2012 05:03 AM
mrblonde108
09-23-2011 08:17 PM
90Bronc
09-12-2009 12:04 PM
jmkelly
06-07-2008 08:48 PM
masterguns2003
01-23-2007 10:25 AM
Quick Reply: Manual Trans Swap 5.8L?
