E40D swap to ZF S542
Old Feb 7, 2002 | 06:28 PM
90Bronc's Avatar
90Bronc
I have a 90 Bronco with a 351W and an E40D. The E40D is slipping in 2nd and 3rd. I want to swap out the E40D to a ZF S542. It bolts up but I am told that they use different transfercases. Does anyone know which t-case the zf s542 uses? The E40D is routed through a BW1356. Also how reliable is the ZF? Does it have any downsides? I am also wondering if I will need a manual computer to run a manual? I assume that it will need a new driveshaft also. I may just reluctantly rebuild the E40D because of the price of the swap but I want that 4.14 first gear(I think that's correct), the overdrive and the reliability in the ZF. Any information regarding either transmission and the swap is much appreciated. Thanks.
Alex
Old Nov 6, 2002 | 11:58 AM
brewer460's Avatar
brewer460
Post E40D swap to ZF S542
a new zf will cost more than it would to fix the e4od. the e4od is the strongest auto for a ford. but if you want to go with the zf you have to lose about 8 inches from your front drive shaft and extend your rear 8 inches due to the fact that the zf is about 8 inches shorter, and a lot of extra expenses. if i were you i would take your e4od to get fixed befor it totaly goes, i recked mine, i lost every thing but park. i had basicly every thing in it replaced and some things upgraded and a 3 year warrinty for 2,400$.
Old Nov 7, 2002 | 04:38 PM
DeGideo's Avatar
DeGideo
I think the ZF 5-speed has a 5.72:1 first gear."Ford has no current plans to offer a five-speed manual with the fuelie 351 unless there's sufficient consumer demand", according to a roadtest article of a EFI351-powered Eddie Bauer Bronco in 4-Wheel&Off-Road's 3/88 issue.The swap could be done,but you'll probably need computer mods,plus a fresh ZF tranny.The ZF 5-speed was used behind 351-powered pickups,so it's not an impossible swap,but it might be cheaper/easier to build up your current E4OD.The 351/ZF 5-speed would be a super-nice combination in a Bronco,however.Good luck,whatever you decide to do.
Old Nov 7, 2002 | 06:31 PM
steve83's Avatar
steve83
The computer won't necessarily miss the E4OD - I helped a friend swap to an M5OD in his '93 Bronco and his CEL hasn't come on yet! Check his writeup on his site:
http://www.broncodata.com/
Old Nov 7, 2002 | 11:08 PM
elliott's Avatar
elliott
It was suggested to me today, that one way to do the auto to manual swap is to get a solinoid (sp) pack and plug the E4OD conector into that. Wrap it in plastic and mount it in weather proof box to make the computer happy. Elliott
Old Nov 7, 2002 | 11:17 PM
TLindquist's Avatar
TLindquist
Old Sep 12, 2009 | 12:04 PM
trucknoris's Avatar
trucknoris
i wana do the same except with a 94 460 truck
i bbqed my e4od and and would love more detailed info on this
07CVPI79F302
Apr 8, 2016 10:11 PM
Davie J.
Sep 17, 2015 01:52 PM
794Dman
Oct 14, 2012 02:09 PM
martinez53
Jan 16, 2011 04:56 PM
cortina219
New Member Introductions
Feb 26, 2008 08:41 AM
