1977 Cab Mount Confusion
Ready to replace the floors and one cab mount on 1977 F100. Been to numerous parts online stores and some show them as:
a. one piece unit
b. two piece (but only one part included)
c. two part (according to picture both are included)
They all list as fitting my truck (which has the two piece now, or whats left of it). Would really like to know what the difference is, as I have seen both used in build threads.
Just want to know what I'm dealing with before I place my parts order.
a. one piece unit
They're seperate parts, as depicted below...
Flashback F100's - USA Made Steel Made Repair Panels On This page will be only USA Made Repair Panels,, not like others that carry those Black Tawain cheap repair panels
It is 2 separate pieces. Just Had mine done on both sides, I got the parts from LMC, no complaints.
Here are the ones I used.
Truck Parts and Truck Accessories
Correct! iirc Dennis Carpenter has the 2pc. welded mount, most other vendors have the cheap stamped piece from overseas, but it is ONE piece so i understand your confusion.
99% of patch panels/sheet metal come from the same source they just rebox it.
Never had any problems with any sheet metal from LMC except the lower door patch panels...They are junk it you try to use it complete but if you cut it off below the body line they fit fine.
I tend to agree here, the panels I got were good quality 18 ga stamped steel, no problems at all with them. The steel is thicker than most of the rest of the truck.
montana_highboy no offense taken at all.
I really try and buy american when I can, but the price difference in the cab mounts/floor pans was just too much to justify, I looked at the ones in your link when I was looking to replace my floors. I'm not a 100% sure those floor pans aren't the same as LMC, just painted, they certainly look the same, and the little made in usa sticker on them actually kinda throws me off, thats the exact same spot that the sticker was on my LMC floor pan and almost all the other pictures show parts in raw steel, but those are primered, just seems suspect to me
I think maybe we have all chinced a bit on some things made in china/taiwan/etc, ever used an eletrical connector from walmart/Lowes? maybe a screw/bolt, etc, etc,......I'd say safely that at least 50 % of anything aftermarket any of us have ever used was probably sourced from somewhere other than the U.S., sorry kinda went off topic on this.....
I do too, that's why i recommended "Flashback F100", i have no dog in this fight, i've had experience with both replacement parts and the American made stuff was heavier gauge, guys are free to buy whatever they want, i'm just offering my opinion.
flashback 100
Thats what I worked on this weekend,drivers floor is installed,and now Ill drill out my cab mount to plug weld,Both my parts came from Flash Back,...were talking solid, does not burn through,HEAVY DUTY,,money well spent thanks Montana,,,I called FB around 9 pm monday night at my door by Wens,,they are good folks I have some lmc lower door panels was starting to think to re ck that and see if fB offers lower door panels no comparison
hollibau
03-26-2000 09:05 PM
