What's the trick?
What's the trick?
Oh smarter people...
What is the trick to removing the inside door handle on a '49? I have gotten the outside handle and the latch assembly loose from the door frame but haven't figured out the next step. Recalling my history, I have not yet unleashed to brute force solution to free the handle. Should I?
Thanks guys,
DW
Thanks guys,
DW
The intererior bezel is spring loaded. Just push the smaller portion of the ring towards the door (or pull the bigger ring away from the door) can't remember right now, and you will see a small pin holding the handles on. The same thing for the window cranks.
Push the pins out and pull the handles off. That's it.
Thanks guys - excellent guidance and response!
Two bonus questions:
What is the purpose of the material that I've seen inside of the door frame behind the regulator (opposite of the inspection panel). This stuff was factory applied and now looks like a dried plaster-ish coating.
What is the cure for an exterior door handle that doesn't move the latch mechanism despite being properly seated? (This is the reason I needed to remove the latch assembly in the first place.)
DW
Reps given.
DW
Reps given.
First answer (guess): sound/temperature proofing
Second answer: Worn out cams or mechanical componets in the latch.
Take a look through the two photo albums of the latch assemblies that I have repaired.
Repair 1 pictures by modelking1 - Photobucket
48-52 Door latch mechanism REPAIR pictures by modelking1 - Photobucket
EDIT: If you want to send me your latch mechanism, I can see what's wrong with it and possibly repair it.
str8patina
04-09-2017 04:15 PM
habby19
05-23-2005 08:45 PM
