Aerostar Ford Aerostar
'92 side door handle
Old Mar 10, 2008 | 10:13 PM
roree's Avatar
roree
Yesterday, I found I could no longer open the side door with the outside handle. As of now, it only opens with the inside one. Anybody have any ideas on this? Thanks.
Old Mar 11, 2008 | 04:42 PM
CarCrazy1001's Avatar
CarCrazy1001
The handle must have somehow disconnected from the latch. You can take off the inside door panel off (it is very easy just some screws) and try to see what is happening. My sliding door wasn't opening at all one time so I took the inside panel off and freed the latch manually because it was jammed.
Old Mar 11, 2008 | 05:40 PM
Pablo-UA's Avatar
Pablo-UA
I had similar problem. To be sure what is going on remove inside body trim, then look inside the door, there are 2 M6 nuts holding handle on. Use 10mm socked to uscrew nuts. try not to drop them inside the door. Remove a handle and you will see what is wrong.
