Gas Leak!!
Gas Leak!!
Ugh.. another set-back.. the Ford Dealership just fixed the sending unit in my 88 Aerostar.. to the tune of (a lot)!! It's nice to see how much gas I have... but I looked under the van today.. and gas is coming from the top of the tank (I did just fill up)!! Any ideas before I head back to the dealership??
I would complain to the dealer, since they did just charge a lot of money doing work in that area. Do it soon, so they have less denyability.
Recently someone posted his work replacing a fuel pump:
https://www.ford-trucks.com/forums/1...nt-1997-a.html
so you can see all the parts involved, and all the places where leaks can occur if you didn't put it together properly.
maybe they forgot to tighten the filler tube & hose on the side? if leaking from the TOP of the tank, then they either missed the pump seal or forgot to tighten the mounting. These people are under time constraints, they're pushed to their limits, quotas, you name it. Just remind them to raise the vehicle properly using the jacking points so they don't damage your rocker panels!
Well.. looks like I'll have to keep an eye on it.. the dealer didn't find a leak.. they filled the van back up and drove it around for a while.. put it on the rack.. and no leak!!?!? My only guess is that they tightened up something while they were under there and didn't want to tell me lol
That's what I'm leaning towards!! I still get a mist on my liftgate.. I crawled under the van.. and the front of the gas tank has fluid on it.. I'm thinking is transmission fluid.. there is a small leak at the shift shaft.. but it doesn't leave any spots on the ground.. and when I wiped it off the back of the van it's not greasy like oil would be.. I guess the next stop is the transmission place lol... I checked the fluid.. it's not low..
kibbie
05-10-2013 05:28 PM
rhw
03-22-2007 11:01 PM
