Sponsored by: Auxito
Gas tank leak - E150
Old Aug 18, 2003 | 05:19 PM
kachup's Avatar
kachup
Hi! I realize ours is a little older than a '97, but still hoping you'll have advice!
We have a '95 E150 with about 110k on it, and just discovered we have a leak in the gas tank? I went to fill it, and in the space between the frame and the gas tank sleeve, there was a running drip of gas down the inside of the frame, dripping into a growing puddle underneath.
Hoping desperately it was the pump and not the van, I tried again at another gas station -- same result!! It doesn't leak any other time, just when the pump nozzle is trying to fill it!
Any hints, advice, suggestions from the pros??? All would be appreciated!!
Thanks!
Old Aug 18, 2003 | 08:48 PM
LxMan1's Avatar
LxMan1
Check the rubber hose from the filler neck to the tank.
Old Aug 25, 2003 | 02:07 AM
flipnflyer's Avatar
flipnflyer
Lightbulb Gas tank leak - E150
We have a used 2001 E150. I was searching for any recalls and found this 3/2001 recall due to potential gas leaks . Not sure about other years, but check it out in case this describes your problem. If so, I would see if it would be covered despite the year of your E150.
Patsy
http://wwwodi.nhtsa.dot.gov/cars/pro...ls/results.cfm
Old Aug 25, 2003 | 07:42 AM
worshiper's Avatar
worshiper
I own a 97 E350 and it was recalled for gas tank leaks. They are putting a cover on the tank to repair them. Hope that helped...
Old Sep 4, 2003 | 04:42 PM
kachup's Avatar
kachup
Thanks for all the advice!!! I checked with Ford on the recall, but it didn't cover our '95. Thankfully the problem turned out to be a crack in the filler hose rather than the tank itself! My checkbook is grateful!
Thanks again for the ideas and advice! I appreciate it!
Kachup
Old Sep 4, 2003 | 08:24 PM
Racerguy's Avatar
Racerguy
Thanks for letting us know what you found
Old Sep 13, 2003 | 02:25 PM
B-O-B'03's Avatar
B-O-B'03
I have a '97 E150 with an Explorer conversion package on it.
I took it in because it smells of raw gas, worse after a fill up and my service tech told me the tank is wet on top and he suspects that it is cracked.
I called a Ford dealer and was told the recall does not apply to my van??
They also told me the tank was about $400 + laobr to replace.
I filled out a complaint on the NHTSA web site today, we'll see what happens.
-Brian
Old Sep 13, 2003 | 08:57 PM
Racerguy's Avatar
Racerguy
The recall applies to certain 1997 through 2001 model year E-150 wagons and E-350 wagons equipped with 159 Litre (35 gallon) mid-ship fuel tanks and built at the Lorain Assembly Plant from April 9, 1996 through November 14, 2000.
kevin-11
52
Mar 22, 2016 12:40 AM
bored&stroked
Jul 31, 2006 01:18 PM
864x4stepside
Feb 18, 2005 10:01 AM
79f150
15
Aug 1, 2003 03:01 AM
