95 f150 4.9 300 no spark
i have spark from the coil to the distribitor i have no spark coming out of the distributor i have replaced the pickup coil inside the distributor coils new ingition modules new also put a new crank sensor plug wires cap roter button relays just gettin no spark out of the distribitor cap and dont know why
on
So you have spark coming out of the coil wire, but not out of the spark plug wires, right? That is either a weak spark that can't overcome the resistance of the ignition system (weak coil) or too much resistance in the rotor, wires, or cap. I've seen bad rotors before and the low end wires that the discount stores sell cause missfires and no starts. If you hold the coil wire close to ground, does it throw a nice blue spark? Slowly moving it away from ground, it should throw it 1/2" or more.
on
You dont have a crank sensor, I guess you mean pip, what ford callls the pickup coil in the dist.... as far as module and other primary ignition, there's no need to check that if your coil is making spark. Sounds like you got a defective cap or rotor. I guess it could be moisture inside the cap also, nothing got rained on did it?
Joshua Dolan
02-20-2018 10:05 AM
JoeVR
12-19-2016 05:40 PM
JayzDaddy
10-23-2014 11:25 AM
94f150inline6
24
12-31-2012 04:40 PM
wayfastwhitey187
11-22-2010 03:56 PM
