9" Swap Questions
9" Swap Questions
I have some questions about swapping a 9' From a 57-72 F100 into my 1954 F100.
1) Is this really just a bolt on, i..e. no welding required?
2.) Are any years better than others?
3.) I am looking for 3.23 gears should I be looking manual or automatic.
Please comment on anything else I should be aware of.
Thanks for your input
Marty
Marty
Marty
Marty
It is basically a bolt on swap. You dont even need to re-locate the spring mounts if you use 1958 or 59 shackles. Yokes on the 9" have a couple different cup sizes for the u-joint so if you find a smaller one it is the same size as the oem axle yoke. YOu may have to have your drive shaft shortened/lengthened.
Find an axle from 1969-72 and the over all length of the axle will be the same also. easiest swap for a rear there is and the gears a super easy to change. the third member just pulls out and you put a different one in. Bullet proof
The '57-'60 would be choice just because the mounting hardware would make it a direct, no mods, swap. The 9" axle itself is basically exactly the same from '57-'67, brakes and all. In '68 the axle changed a bit to allow for wider brake shoes up to '72. This modification didn't alter the overall width though. All the 9" axles from '57-'72 share the same overall width. The difference in the brake width change was made up within the axle itself.
Did the axle change or did the backing plate change (deeper dish/more offset) to accomodate the wider brakes?
Actually I need to qualify my answer above. I put my D44 brakes, complete, on the 9" and the drum was sticking out proud of the backing plate by 1/2". That implies the backing plates were not changed. At that point I didn't go any further, just used the 9" brakes. Just looking at them the 2.5" backing plates certainly appeared to be dished more than the D44's 2" plates.
Here's a picture to illustrate kinda what I'm referring to (Both are 9" axle shafts out of trucks one early, one post-'68)
1968/72 F100: There are two different 9" rear axles. One has 28 spline axleshafts with/without Limited Slip.
The other has a 9 3/8" ring gear, 31 spline axleshafts and 4 pinion Traction-Lok.
Only 5 parts interchange between the 9 & 9 3/8: Housing gasket, pinion seal, one pinion bearing and cup, pilot bearing retainer.
EVERYTHING else is different! Parts for the 9 3/8" can be difficult to find.
1968/72 F100 rear brakes are the same: 11" x 2 1/4" / 1948/52 F1, 1953/67 F100: rear brakes are 11" x 1 3/4"
Mid year 1969 9" (not 9 3/8"): Ford changed the differential bearings from ball to "slim line" tapered roller.
Warranty Plate AXLE code for 3.23-1 ratio w/o Limited Slip: 1965 = 07 / 1966/72 = 17 / FoMoCo didn't offer a 9" with Limited Slip in F100's until 1968.
1965/72 F100: 3.23-1 commonly found with A/T, very few M/T's came with this ratio.
1965/72 F100's with a two piece driveshaft have a u-joint that has (2) 1310 cups, (2) 1330 cups: Ford: C5TZ-4635-F / Spicer: 210392-X
Midwest Dually
04-11-2010 12:59 PM
jmadsen
11-26-2008 10:34 AM
85'FordF-150
03-08-2004 07:54 PM
