The title says it all. I've been all over the web looking for where this is.
Several references ended up being the ABS computer. I pulled it and drove all over town so I know that's not it.
Its inside the van, pass side, under the heater box. Its covered with a plastic cover And under the hood there is a 10mm bolt that you have to undo before you remove the ECU from inside the van
i took out my battery and reached under the ac box and felt around till i found it there is a big elect conector about 1 by 6" long with the bolt in the center of it
Been a long time since your help. I was called out and got involved elsewere but I came back and was able to swap out the ECM just as you described. Thanks for your help.
