HELP! Getting to the computer
I need some help.. 1990 E150 4.9/300 Factory Propane. (VIN Engine code 9).
I want to get to the computer. It's located under the heater-blower assembly. I've removed the blower motor. I've removed the 4 nuts from around the blower assembly. I yanked on the assembly, but it seems to be stuck at the bottom.
All I could see was a bolt of some sort. I tried to removed it, but realised it was part of the PCM's connector!
It's almost as if the PCM is holding the blower assembly in place, but I can't get to the devil without removing the blower assembly!
Do I have to get to it from inside the cab? At this point, I'd rather not remove the heater core if I don't have to... Haynes and chilton seem to be of no help.
Anything can help!
Thanks all.
-Pauli
You do the rest from inside the van.
Firs remove the plastic under the heater and the back bolt with the braid on it and then it comes out.
