'66 econoline gauge help please
Old 10-01-2012, 09:57 PM
SwampyBull's Avatar
SwampyBull
SwampyBull is offline
I have a 1966 econoline supervan that has bad gauges in it and that's the next big thing in the restoration. What are my options?
Old 10-17-2012, 02:53 PM
scf100's Avatar
scf100
scf100 is offline
TRY GREEN AUTO SALES FOR NOS....I bought a speedo for 150.00 and to restore it was 250.00
Old 10-31-2012, 08:36 PM
economan's Avatar
economan
economan is offline
you sure the gauges are bad!?
if they are both not working you should check the constant voltage regulator on the back of the cluster, very often thats the problem.
alllllso don't forget the same gauge cluster was used in the 57-60 f series & a modified version in the c series from 57 all the way into the 70s or 80s. also on some school bus chassis.
Mikie
near ottawa canada
64 econo p/u 58 merc m-100 panel
Old 11-01-2012, 07:41 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Fuel & temp gauges don't work at all, or their needles swing wildly back/forth on their own?
B7A-10804-B .. ICVR-Instrument Cluster Voltage Regulator / Regulates "juice" to the gauges, attaches to back of instrument cluster (Motorcraft GR-507) / Obsolete
Last MSRP: $28.24 / Dealer net cost: $12.71.
Applications; 1961/66 Econoline // 1957/66 F500/750 // 1957/59 Ford Passenger Cars / 1958/59 Thunderbird.
Most likely available from autoparts stores, but make SURE to take the original with you to match it up. There is another that is similar, but it's not the same.
B7A-10804-B =
JST AUTOMOTIVE in Lebanon TN has ONE = 615-443-3086.
WOLFE FORD in Lidgerwood ND has ONE = 701-538-7337.
Green Sales does not have it.
Old 11-01-2012, 09:06 AM
OGB's Avatar
OGB
OGB is offline
get a new temp sending unit from napa check engine ground connections (both end) run a ground wire from gas tank to frame (drill small hole in flanged seam in perimeter of tank use small sheet metal screw). That should solve both problems, if needles are moving chances are gauges are good.
Old 11-01-2012, 09:14 AM
NumberDummy
When the ICVR begins to fail, the temp & fuel gauge needles do "the hula" .. swing wildly back/forth on their own.
When the ICVR fails, the needles no longer move. If both the fuel & temp gauges aren't working, it's most likely the ICVR has failed.
BEN WHEELAN
02-26-2018 11:29 AM
1972RedNeck
03-22-2015 12:07 PM
rusty2872
11-24-2014 03:12 PM
westtex
06-18-2012 03:49 PM
nojeffgordon
06-07-2004 10:07 PM
Quick Reply: '66 econoline gauge help please
