Kickdown Linkage
Old 09-29-2012, 11:42 PM
Fordzilla80's Avatar
Fordzilla80
Fordzilla80 is offline
Kickdown Linkage
Hey guys, I was wondering if somebody could give me a quick rundown on the purpose and function of the kickdown linkage on a C6 transmission. My old C6 had it, my new C6 did not. I still have half of the linkage from my old C6, and I'm wondering If I need to run the kickdown linkage with my 400, if they even came with kick down linkage.
Thanks!
Old 09-30-2012, 08:33 AM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
The linkage does what the name implies - kicks it down a gear with heavy throttle. You do not have to have that linkage, but you won't get the full-throttle downshift you'll want. The linkage was pretty standard and I have some if you want, but the carb has to have provisions for it. On an E'brock that's extra as they don't come that way unless requested.
Old 09-30-2012, 11:36 AM
Fordzilla80
I'll really have to think it over. Truth be told, I'll probably go without it for now, and if I end up wanting it, I can always add it later.
Thanks Gary!
Old 09-30-2012, 11:48 AM
ctubutis's Avatar
ctubutis
ctubutis is offline
I personally wouldn't try to run without it but I guess it's not absolutely critical, it just won't behave as well.
Old 09-30-2012, 12:11 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
When adjusted correctly the linkage only moves in the last little bit of throttle travel.
Old 09-30-2012, 12:47 PM
Fordzilla80
Biggest reason I ask is because I still have the transmission side of the linkage from my old 300/C6 setup.
But that linkage runs to the passenger side of the trans, since the intake on a 300 is on the passenger side, and that's where the carburetor sat. I'm not even sure if the linkage I have would work with a 400.
Loosescrews
01-06-2018 11:13 PM
Daplumma
04-06-2006 01:53 PM
Pilgrim
11-08-2005 04:51 PM
superswamper
08-09-2003 09:56 PM
Quick Reply: Kickdown Linkage
