Kickdown linkage
Old Apr 2, 2006 | 06:22 AM
Daplumma's Avatar
Daplumma
Kickdown linkage
Was working on the truck yesterday and it appears that the kickdown linkage does not work.I can't see any part of the carb linkage that would make it kick down.The truck has a Holly double pumper and works very well at eating lots of gas but I would like the kickdown to work.Does anyone have a closeup picture of a properly working 4 barral with the kickdown linkage?By the way tha tranny is a c-6.
Thanx,
Joe
Old Apr 6, 2006 | 01:53 PM
William's Avatar
William
If the linkage from the carburetor to the kick down arm on the transmission is missing you will need to replace it. You really don't need it and using your truck without it will not hurt anything. I use LoKar kick down cable on mine. Not expensive and easy to install.
