High mileage overhaul
What is the general rule or past experience of when these engines might need some sort of overhaul?
For longterm life expectancy is there a time when bearing journals, lifters, or any other items I'm not even thinking about should be considered for replacement?
Thanks.
Thanks.
there are some here that are over 500K and have only done top end stuff I think
Run6.0RUN is the member Im refering to I know most of his miles are Freeway so FWIW
Usually in a gasser the valve guides wear and start sucking oil at 200-250K But these Diesel seem so Bullet proof especialy in the Bottom End
How many miles do you have stacked up Colm???? 300K yet???? I think you just got it Broke In
Run6.0run I'd say is the exception. I think he posted that he once did 10 days without shutting her off.
I'm usually doing 800 - 1,000 miles +/- each week. With summer and fall being high and winter and spring usually less. About 35k to 40k per year depending on business.
I'm 30% low speed limit roads and 70% highway I'd say.
I probably use the starter about 5 -6 times each working day with the stops I make.
So right now I'm at 260k miles. I need a new HPOP, a new oil pan, I have a leaking seal at drivers side rocker arm carrier and a leak at CMP sensor.
The harness is getting old. Everything feels brittle and in a few areas I've repaired it. IPR pigtail is repaired. ICP pigtail is replaced. FICM tabs are broken. While the top is apart I may as well do a VC-9 flush myself first and then add a new oil cooler to the list.
I would love to do the work myself but I don't have the time and I need the truck to make a living .... so I'll have to pay someone to do it. I have the calculator out at the moment and I'm trying to make the right decision about the upcoming repairs.
I don't want to do all the repairs mentioned above and then have something major go wrong in 12 months time when I'll be at about 300k miles.
EGR delete
ARP studs and OEM gaskets
Blue fuel spring
DC Power 180 HP alternator
Bulletproof Diesel aluminum radiator
FICM with 2yr from FICMRepair
Coolant filter
Power steering filter
Fumoto oil and block valves
New HPOP will be billet pump by Dieselsite
Riffraff boots on my bench waiting on my ccv reroute and intercooler replacement (or cleaning)
Edge Insight CTS with EGT
Pillar pod with fuel pressure, low oil and HPOP pressure
Rebuilt tranny at 225k miles
Turbo rebuilt at 190k miles
Last oil cooler at 190k miles. Current spread of 8* at test criteria
Water pumps, starters, ICP sensor, cam sensor, crank sensor, thermostat etc along the way
All original injectors and glowplugs
Got your PM by the way. Thanks.
Blue fuel spring
Coolant filter
