Are those "High Mileage" oils any good?
When Valvoline's MaxLife was first introduced, my reaction was the same as lasher's. I scoffed at the ad because if you look closely you will notice the valve stem seals depicted are cork, something that hasn't been used in years. Almost anything will swell cork seals and improve their sealing ability. Just a clever marketing ploy I thought.
Well, there was a promotional special the day I need to stock up on oil at the local parts store. I use Valvoline anyway and what the heck, it was cheaper, so I bit. Now, all this may just be coincidence, but after 3 oil change cycles, that sticky lifter I've had for years quit making noise on cold start up, my rear main seal leak slowed considerably and is just about gone, dropping my consumption to barely 1/2 qt per 3,000 miles. At 223,000 miles on the original engine and transmission, I think it qualifies as high mileage and with the favorable experiences, I am sticking with the MaxLife.
From personal experience, I am quite leery of using tranny fluid in anything but approved applications. To wit, I ran out of oil for my air powered tools and decided to try ATF in place. The first sander quit within minutes and I attributed it to old age and grabbed another. It too died within minutes, both from siezed seals, swollen from just a few drops of ATF fluid. Moral of this story: Some compounds can tolerate ATF and others are ruined by it.
The only way to stop a leak is fix it, or make it swell bigger.
ive been using the max life for about the past 5 changes and ive loved it. ive used the 10w40 and 30. i did have a little tap on my right bank and after the 2nd change it was gone. before i went through a qt a week and now it doesnt need anything, wonder oil huh. well does anyone know anything better? i dont even touch penzoil, ive just heard bad things, but you never know.
what i do not understand is if this max life oil is so good for older engines why would it not be good for a newer engine if it meets the weight requirerment. If not because it will hurt a newer engine i would think that it may not be good for any good running engine. it would only be good for an engine with problems such as burning oil or noisey.
I think I'm going to send them a e-mail to see if they will a logical answer.
Your high mileage oils will contain additives such as nitriles, organic phosphates, some esters, and/or aromatic hydrocarbons. These additives are designed to swell seals. They are used also in any PAO basestock synthetic such as Mobil One, etc.as the PAO basestocks do not support any seal swelling ability. If you have an engine that is leaking at the seals, give it a try. They usually are also on the thick end of their respective viscosity range. If the engine is burning oil, I would suggest moving to a CH-4 or CI-4 oil such as Delvac, Rotella, or Delo 400 in 15w-40.
81POS!
01-16-2011 03:36 PM
