HELP much needed intel ....
Hey I have a 94 F150 that i have put a 95 302 Ho out of a mustang and iu change the intake and the assessors to the truck intake and accessories but the HO motor does not have the bottom end torque that the truck motor had i just need to see what i can do to get i back. the Ho is fine after about 2000rpms so do i need to change the cam? Or is their some other things i can do ..and thanks
You could easily bump the base timing up to 12-14 BTDC. That is a common modification on these trucks. Beyond that there is not much you can do with the stock setup. That HO cam builds power a little later in the power band than the stock cam did. You have a bunch of tire, but a reasonable gear to compensate so you are on the right track. More cubic inches or a more intensive engine upgrade in the 5.0L may be the answer here.
Some might suggest 1.7 roller rockers, that may net you a few more ponies but I do not think it is going to help the bottom end torque much.
put a stall converter in it so you never lug the engine down below 2,000rpms
something like this http://www.transdepot.net/product.as...FQJx4AodnVcABA
(I can't vouch for that brand never used it just the product of a quick google search)
and I would stay away from revmax converters, that is what i am running now. It was too short so i had to remove the shim between the engine and tranny and add that much shim between the crank and flexplate to get it to engage the front pump completely so it would not leak. On top of that it is advertised as a 3600 stall but really stalls at 4,000 but it has a nitrous anti ballooning plate and a billet front cover
tci and b&m also make junk converters they use a cavaler or similar 4cylinder low power POS car converter as a core and modify it to fit specific applications. you might be fine though since you are all stock and probably don't have the power to make one balloon
if you want to get the best converter go with a neal chance converter $$$$$
Rusty96
08-28-2017 05:33 PM
jack orchard
07-10-2017 06:09 PM
charkane
03-12-2012 07:25 PM
reed1951
10-27-2007 12:24 AM
