2007 missing problem
I know there is a tun of info on the spark plug problem on the f-150. Here is the problem I have and I don't know where else to look.
cylinder #3 misfires
1. swapped coil with #2 cylinder and still throws #3 misfire code.
2. Changed the plug on #3 and still the same code #3 misfire.
any ideas where to look next?
thanks
Jason
thanks
Jason
Jason
Those of you who had fouled plugs when you changed them out, I would be really concerned if they were fouled from excess fuel. That could be expensive if the injector stuck open and the engine hydro-locked. I would be proactive and check the source of fouling and get the cause fixed as well to avoid future problems.
The old style plug was a common cause of the misfires under heavy acceleration too. The new style with the larger gap at the end is what fixes that the most.
I did have the older style plugs. I also had 68000 miles on the truck. Dealer said Ford recommends replacing the plugs at 60000 miles. I was expecting to get 100000 miles out of the originals, with 4 breaking like they did I'm glad I didn't wait. Plus my fuel economy and pickup DID improve after the plugs were replaced. My only issue was the exhaust vapor that started seeping into the truck almost immediately after getting them done. After 3 trips back to the dealer I found information on another site that explained they needed to re-torque the plugs. They listened re-torqued the plugs and the odor disappeared immediately! I'm finally a happy camper again!!!
Tree Doc
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
08-29-2010 05:23 PM
