2007 missing problem
Old Sep 19, 2012 | 08:05 PM
jawsfree's Avatar
jawsfree
I know there is a tun of info on the spark plug problem on the f-150. Here is the problem I have and I don't know where else to look.
cylinder #3 misfires
1. swapped coil with #2 cylinder and still throws #3 misfire code.
2. Changed the plug on #3 and still the same code #3 misfire.
any ideas where to look next?
thanks
Jason
Old Sep 19, 2012 | 08:35 PM
shawn001's Avatar
shawn001
hate to sy it but mine ws the same, cyl 3. changed it all same s you. changed all 8, all better.....
Old Sep 19, 2012 | 08:37 PM
shawn001's Avatar
shawn001
wow sorry for the disaster above - ipad ..... mine was the same situation, except cyl 1. i had to replace all 8 before it felt better
Old Oct 1, 2012 | 09:30 AM
jawsfree's Avatar
jawsfree
Changed all the plugs, one broke and now it runs much better. I am still getting occational misfires. Drove 3 hours on the interstate and got 10 misfires from severa random cylinders. Is the occational random misfire normal or do I need to do something else?
Jason
Old Oct 1, 2012 | 10:21 AM
GwarForAll1021's Avatar
GwarForAll1021
Did you replace all the coils?
Old Oct 1, 2012 | 11:08 AM
jawsfree's Avatar
jawsfree
No just the plugs.
Old Oct 1, 2012 | 01:53 PM
GwarForAll1021
Originally Posted by jawsfree
No just the plugs.
I would highly suggest replacing all of the coil packs. I have seen many people try to tackle the coils one at a time and end up losing. I wasn't happy until I replaced all of the coil packs at one time and things have been golden since.
Old Oct 1, 2012 | 07:51 PM
Greg B's Avatar
Greg B
It could possibly be the boots on the coils. Did you replace them?
Old Oct 2, 2012 | 08:01 AM
jawsfree's Avatar
jawsfree
No but they are in great shape still flexible and clean. I did put the spark plug grease on every boot to make sure I had good contact.
Old Oct 6, 2012 | 02:59 PM
ThirstyFX4's Avatar
ThirstyFX4
I had a miss on heavy acceleration, had to replace all 8 plugs (4 broke). That solved my problem. I had fouled plugs.
Old Oct 7, 2012 | 06:50 PM
shawn001's Avatar
shawn001
same with me replaced all. all good now
Old Oct 8, 2012 | 06:34 PM
Greg B's Avatar
Greg B
Those of you who had fouled plugs when you changed them out, I would be really concerned if they were fouled from excess fuel. That could be expensive if the injector stuck open and the engine hydro-locked. I would be proactive and check the source of fouling and get the cause fixed as well to avoid future problems.
Old Oct 9, 2012 | 07:11 AM
Coskid's Avatar
Coskid
The old style plug was a common cause of the misfires under heavy acceleration too. The new style with the larger gap at the end is what fixes that the most.
Old Oct 12, 2012 | 04:06 PM
ThirstyFX4's Avatar
ThirstyFX4
I did have the older style plugs. I also had 68000 miles on the truck. Dealer said Ford recommends replacing the plugs at 60000 miles. I was expecting to get 100000 miles out of the originals, with 4 breaking like they did I'm glad I didn't wait. Plus my fuel economy and pickup DID improve after the plugs were replaced. My only issue was the exhaust vapor that started seeping into the truck almost immediately after getting them done. After 3 trips back to the dealer I found information on another site that explained they needed to re-torque the plugs. They listened re-torqued the plugs and the odor disappeared immediately! I'm finally a happy camper again!!!
ericash25
Modular V10 (6.8l)
Apr 27, 2018 07:37 AM
Tbanks1382
Jan 24, 2017 06:48 PM
fordcrzymike
1997 - 2003 F150
Feb 4, 2013 06:17 AM
Tree Doc
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Aug 29, 2010 05:23 PM
73effie
1983 - 2012 Ranger & B-Series
Aug 16, 2009 12:27 AM
