Rear Wheel Well Liners
Now I know why Fluid Film works so well. It consists primarily of lanolin. I know lanolin is used extensively in underground mining to protect electrical connections on machines. The underground mining has severely corrosive operating environments and good old natural "ram jam" beats anything else out there for corrosion protection.
So I just applied a coating of Fluid Film to the underside of my 2012 truck as part of winter prep. I poured a gallon of Fluid Film into my Wagner Paint Crew Plus sprayer and it made the job super easy. Literally went on in a few minutes and I ended up using pretty much the whole gallon. The cloud from a high pressure airless sprayer is pretty intense under the truck so make sure you wear goggles and a respirator. I was covered head to toe in the cheap throw-away coveralls and head sock. It took longer to clean everything up then to spray on the fluids!
I'm going to go ahead and install the wheel well inserts too, just because it will look better. Those are easy to remove to do another application of Fluid Film next year. Maybe I'll beat this damn Illinois rust for once!
I had worse snow/ice build up on my F250 without liners in the rear than I do on the F150 with liners.
Not sure about mud flaps, might be helpful on my f150. I get a big nasty chunk of frozen ice/snow packed up along the front of the runner board which will get bad enough to rub on the door if I don't chip it out.
I installed a set of liners into my super duty three years ago, they do a great job of keeping mud sand and snow off the metal leaf springs etc. I wish i would have done it years earlier because even with extreme maintenance and fluid film spraying etc my drivers side wheel well lip just popped a #2 pencil eraser sized bubble two days ago, since winter is here im gonna let it go till spring and replace the bed side.......
galaxy S4 using IB AutoGroup
fordiesel69
2004 - 2008 F150
12-07-2016 12:40 PM
fordman19762003
1999 to 2016 Super Duty
08-31-2013 09:49 PM
