freeze plug
freeze plug
question, has anyone changed out a freeze plug with the engine still in the truck? I thought I had blown head gasket, but appears to be a freeze plug so need to know if it is possible to reach driver side forward plug through the wheel well? Is it up behind the motor mount or just where is it at as far as getting to it?
Thanks Hank
forgot, its a 94 4.0.
Thanks Hank
Ok found the real culprit, its the gasket on the timing cover water gallery! leaks out that why no water in oil etc. Anyhow gonna take it down to a shop monday and see what they will charge to replace the gasket and timing chain etc while its apart. It will take them 2 days at most, me 2 weeks working on it part time.
BTW, can barely see the freeze plugs from the wheel well with the tire off!
jules
01-09-2001 06:31 PM
