Project: 4Spd thread
#62
Yeah.
I've never messed with a warped clutch disk before new or used, it's
never been an issue even used all sorts of junky looking disks in dune
buggies too. Slapped in which ever one looked best at the time and go.
That little bit of warp-age cause all the trouble the OP's been having? :)
Cool videos, P, the first one was way better than the second one tho. ;)
The inner and outer pilot bearing hole business threw me until I saw
your picture (thanks) and realized it was just your way of describing it
and there really wasn't an inner and outer pilot hole. LOL :)
And your picture brought up another point... is Rockauto's data base
messed up on the 460's pilot bearing outer diameter? :/
Alvin in AZ
ps- Wow went back and read this thread from the start, I'm into too
many threads on too many forums I guess. :/ Anyway, cool thread! :)
And BTW a T18 only weighs 150 pounds is a T19 ~10 more pounds? ;)
Alvin in AZ
#65
Update.
Disc was bent a bit. Whoops. I have it driveable now, albeit the pedal must be just about to the boards for the clutch to release, and that's with the rod adjusted 'tight'.
In any event. I realized something. I hate the T19. In fact, i feel like I'm driving a small school bus. The 5.11 first gear even with 3.25:1 rear is pretty much unusable, and the splits are a bit much for me.
Sooo..
I went and got one of these.
Sooo..
#66
Update.
Sooo..
Sooo..
< Jealous!
Does Tremec have Big Block bellhousings?
I'd love to have a 5 or 6 speed in place of my C6
#70
#71
I think my fan club here dissipated since I dropped the T19, lol.
In any case.
I used an 88-98 Chevy C/K Hurst shifter stick
This is in 2nd gear.
A litttttttle close to the seat (all the way back, btw) but it works. Comfortable to shift and drive.
3rd gear.
You could possible use the other S10 stick, which is the same height, but not as much 'lean back', but, boom, here it is. I need another transmission floor pan, as I have a thin street sign covering the now-swiss-cheesed panel.
In any case.
3rd gear.
#72
Good call! :)
"Showcasing the size difference. Yikes."-psquare
A transmission guy told me as a general rule the father apart the main shaft
is from the counter shaft the stronger the transmission.
Alvin in AZ
Alvin in AZ
#73
LOL. The TKO-500 is rated for 500 ft lbs. In a 2wd street truck like mine with street tires, I think I'll be fine, it just spins anyway. Gear splits with the TKO are 3.27 1.97 1.34 1.00 0.68. Much more usable for my use, IMO.. I'd have done a T5 originally, but....... yeah. I have a T19 on Craigslist if anyone is local to me, lol.
#74
#75
Cool, thanks for posting that. :)
...I'm -starting- to see a pattern in transmission designations. xD
Believe it or not that's how my '75 F150 360FE+factoryA/C+PS came from
the factory.
The trick is to buy one of those hoses that you cut-the-legs-off-of to make
it fit and don't cut it where the hose company sez to. xD
Cut the horizontal leg the length you need to push the vertical leg back. ;)
(as if you didn't already-done-knowed-that)
1/2" space has been plenty for me, my belt's never touched the hose.
Alvin in AZ
"Van" pulleys and "truck" radiator hoses do not mix.
the factory.
Alvin in AZ
