On my 73 F-250 with a 460, I had the common problem of getting the oil pan out because of the clearance between the tranny and the cross member. Everywhere I searched, the solution was to jack up the motor to allow clearance for removal. What I did instead is put a jack on the drivers side of the cross member. Jacked it up to unload the suspension, and the pan came right out between the cross member and the axle. Not sure if anyone has done this, but I thought I would mention it. Note, I did remove the oil pump before doing this.
