Oil pan removal
Old Aug 17, 2014 | 01:47 PM
Crash F250's Avatar
Crash F250
Oil pan removal
I recently acquired a 77 F250 Supercab with the 351M. It has a small oil leak at the front of the oil pan. I have the seal to replace the old one. My question is, can I drop the pan without having to lift the motor? I climbed under the truck and it looks pretty tight so before I started loosening everything I thought I would ask. If I do have to jack up the motor whats the easiest way to do it? I dont currently have a cherry picker so that could pose an issue. I appreciate all the info I can get.
Old Aug 17, 2014 | 02:40 PM
Jdeshler's Avatar
Jdeshler
Is it a 4x4 or 2wd? If its a 4x4 you can drop the axle but if its a 2wd I'm afraid you may have to raise the motor.. I'm sure there is someone here whos more knowledgeable about it
Old Aug 18, 2014 | 01:30 AM
Crash F250's Avatar
Crash F250
Sorry I forgot to mention that, it is a 2wd so chances are Im going to have to raise the engine.
Old Aug 18, 2014 | 06:33 AM
SS76F150's Avatar
SS76F150
I have a 76 F150 has a 390 I replaced oil pump had to rent a cherry picker to get all back together.
79sparky
Nov 12, 2013 10:03 PM
balderman
Feb 15, 2009 09:15 AM
bearclawii
Mar 26, 2006 07:34 AM
ford390gashog
Jan 21, 2004 08:58 AM
78roughride
Jun 1, 2003 03:52 AM
