Can the hpo-rail leak enough to cause a no-start?
Just got finished bragging in the 'It's time to say bye bye" thread how great my truck is, next day it did a no-start hot again. I've had a couple of these, replaced the stand pipes and dummy plug o-rings when I did injectors and they only lasted 6000 miles and blew, chalked it up to some e-bay guy selling me the old o-rings as new ones, then blew out some injector o-rings, chalked it up to cheap Bostech injectors, so when this happened, I was sure it would be the ones under the other valve cover.
Did the air test, and couldn't really hear anything but a slight hiss coming out from under the passenger side valve cover...the side I'd already replaced the injector o-rings on. Pulled it apart, and found nothing wrong. Injector o-rings look perfect, stand pipe and dummy plug looked perfect. Set the oil rail on the bench, and clamped 4 rubber plugs on the injector sockets, covered the standpipe with my finger and hit it with air, and one of the sockets was leaking. This has happened before, and an Italian tuneup will cure it (full throttle for a few miles), however, this time it won't.
Any other time I've done the air test, there was no mistake where the leak was, this time, I can't tell. I never hear of any of the techs talking about replacing the o-rings under the sockets, but I can't think of anything else. (I'm only getting 0.056 volts at the ICP - the same as usual when it had a hpo leak, and it starts cold, and runs great) Could the hpo rail be the problem?
Leak test with valve cover off and rail installed.
It could be the O-ring at the top or the rail nipple.
There is a took for replacing the nipple and I hear that
the O-ring can be replaced. Just it's a bear.
This is the tool to do the nipples
Socket High Pressure Oil Rail Ford Powerstroke 6.0L T444E ICP Leak Repair Tool | eBay
The injector top O-rings you will have to ask where to get them I only know is they
did not come from Ford.
Sean
Sean
BLADE had mentioned to me before that the alliant o-ring kit has the top one in it. comes as kit cant buy then separately.
lupuseven, Yes, you can get the kit from Alliant, I bought some a few months back. You can also get the kit from Ford, but it comes with a new injector...
I did test the oil rail on the engine with the valve cover removed, just a gentle hissing.
Ok, as I was typing this, I was on the phone to my trusted diesel place, and he told me the socket o-rings are in the injector o-ring kit that I already have here. So, I guess I'm gonna build a socket to get those things out - I don't want to pay $150 and wait for 10 days for the thing to show up in my PO box.
I wonder why Navistar couldn't have made a few more places on the HPO to leak - 30 isn't hardly enough.
8 injector o-rings.
8 high pressure rail o-rings.
2 stand pipes with 3 o-rings each.
2 dummy plugs with 2 o-rings.
2 branch tubes.
1 STC fitting.
1 plug in HPOP. (I think)
As an aside, if anybody in the Alberta area has problems, call Taber Diesel. These guys are friendly, will take time to explain stuff to you without selling you anything, and can fix anything. A modern day business with old fashioned values and service, they rock.
8 injector o-rings.
2 branch tubes.
1 STC fitting.
ALIANT POWER INJECTOR ORINGS PART# AP0002
http://alliantpower.com/seals.html
Holy smoke they changed there website
No, I couldn't find the part on how to change the o-rings in the rail. I already have the AP002 kits from when I changed the injector o-rings.
Was working on it till about 10 minutes ago, dropped the torx down under the motor, cussed for a couple of minutes and came in the house. I HATE those 2 torx headed bolts under the HVAC.
I will spread some reps around when I get this thing running, and I will come back and post what happened. I try to complete these threads with an answer to the problem, and make the title searchable so maybe we can help somebody in the future.
Nobody has said if the rail o-rings can leak enough to cause a no-start, but I'm assuming they can, and that's what my problem is. Trying to get my hay up, just lost the long weekend to our local rodeo, and trying to get my 1979 F150 ready for the car show this weekend, and the drag races the next, so the poor old Super Duty is kind of getting ignored.
Decided to rep right now, and I got the same thing about Blade35, I guess I've repped him half to death already...
I'm talking about the o-rings IN the high pressure oil rail itself, not the injector o-rings. That's where the air is leaking from in the air test. Spent 2 hrs this afternoon building a tool to get the nipples out. It's a real pain - the rocket scientists that designed them left about 20 thousands of an inch between the nipple and the edge, I had to build 6 separate pieces with lots of grinding and finessing, then weld the pieces together. Got one nipple out and stripped the tool. The one on e-bay is 150 bucks and at least 10 days away in Texas, or I wouldn't have bothered.
I'm heading to the border tomorrow to pick up some race parts, and I'm going to drop the rail off at Taber Diesel (one more shameless plug for them) and let them work on it. The o-rings weren't in the AP002 kits anyways.
I want my truck back!!!
David - I don't think he is talking about the dummy plugs. I think he is referring to the recessed plugs that are part of the rail itself (or maybe also the end caps). I have never heard of them leaking:
You can see the plug in between the ball tubes (two on each side):
2005 Update Page 05 Turbo High Pressure pump/Discharge tube-Oil Branch Tube-IPR Valve
