Relay harness build
What type of wire? Insulation type? If it's the crap wire they sell at the parts store, use 12AWG. I wouldn't get relays with preterminated connectors, get ones with blade terminals and terminate yourself with insulated spades.
If you can find it, get a blank connector shell and terminal kit, and install that on your new harness. One like <a href=http://www.ebay.com/itm/Bosch-style-4-5-Pin-Relay-Connector-Bracket-and-terminal-kit-/150875303440>this</a href>.
What type of wire? Insulation type? If it's the crap wire they sell at the parts store, use 12AWG. I wouldn't get relays with preterminated connectors, get ones with blade terminals and terminate yourself with insulated spades. This is what I did with my relays.
Better yet, get a blank connector shell and terminal kit, and install that on your new harness. One like <a href=http://www.ebay.com/itm/Bosch-style-4-5-Pin-Relay-Connector-Bracket-and-terminal-kit-/150875303440>this</a href>.
I'll be doing this for all my added relays once I get my auxiliary lights installed.
I got 12awg from home depot. It was cut wire so the guy gave it to me at 16 cents a foot; 19 ft of white 15 of black. I'm hoping I have enough, we shall see. Did anyone who has built a harness switch over to H4 sockets or just stick with 9004 sockets? If so it it any problem getting the H4 to stay in the existing headlight housing? Should I just stick with 9004 sockets or what? Thanks!
madpogue
07-19-2014 10:02 PM
xxshine
1983 - 2012 Ranger & B-Series
01-27-2012 01:25 PM
