New member, old truck
Old 07-29-2012, 04:02 PM
timgort's Avatar
timgort
timgort is offline
Just picked up a 1960 f100 4x4 with the smaller straight six. Was a three on the tree, but the transmission was replaced with a '57 four-speed and a three-speed transfer case. Came with lots of extra parts, including another engine, old transfer case and axles and radiator and other misc stuff. Needs a master cylinder and runs, although a bit rough. I got it home with no brakes. It seems to run best with the choke on, not sure why. I'm a total Ford newby and live in Marquette, MI. Any general advice would be great. Have an extra master cylinder but the existing brake linkage is too long. Overall, the cab is rough-steps are rusted out and fender are rough all around...
Old 07-29-2012, 05:14 PM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
Tim Welcome to the orphanage these trucks are addictive, next thing you know you will be combing wrecking yards, cruising through parts catalogs, buying new tools and challenging your skills.
Ejoy the madness and good luck in your quest.
Did I mention we like pictures, so hang around and post some pictures.
Old 07-29-2012, 07:17 PM
timgort's Avatar
timgort
timgort is offline
Old 07-29-2012, 08:30 PM
timgort's Avatar
timgort
timgort is offline
Let me try with the photos again:
Photo by timgort • Instagram
Old 07-29-2012, 08:59 PM
spurredon's Avatar
spurredon
spurredon is offline
Welcome to the land of forgotten fords! Glad you got a nice truck. Looks kind of complete from the pic you posted. If you are serious about it, you will end up tearing it down to nothing and rebuilding. 50 years of sitting around can have that effect on a truck!
Old 08-26-2012, 06:39 PM
timgort's Avatar
timgort
timgort is offline
Thanks all. It's nearly road-ready. I'm looking for a replacement or original air filter for my single-barell carb. Any ideas?
Tim
Old 08-26-2012, 07:20 PM
spurredon's Avatar
spurredon
The paper element or the entire breather?
Old 08-26-2012, 07:44 PM
timgort's Avatar
timgort
timgort is offline
Thinking both. I don't care if they are original or not, a replacement would be better than the ATV-looking air filter that's no there now.
Old 08-28-2012, 05:28 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Paper element? I-6 & V8 trucks came with oil bath air cleaners as standard equipment thru 1967.
The only vehicles with 223's that came with dry type (paper filter) air cleaners were 1957/64 Ford passenger cars.
1968 was the first year that Ford offered dry type (paper filter) air cleaners for trucks. The oil bath's became an option (thru 1979).
Old 08-28-2012, 09:41 AM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
Dang Tim, you got a real nice looking truck there! Welcome and good luck with your project, however you intend to do it.
Old 08-28-2012, 10:29 AM
arctic y block's Avatar
arctic y block
arctic y block is offline
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
http://i285.photobucket.com/albums/l...ghtsafter1.jpg
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
Old 08-28-2012, 02:58 PM
hotwater6's Avatar
hotwater6
hotwater6 is offline
I see it has rust out in the usual places, though it's not as bad as mine ('59 4WD). You can get patch panels for that rarely reasonable. I wish I had your mirrors, they are not easy to find around here. The 223 engine is a good one and these trucks are geared to pull a barn down.
I also like the color. (Help me out here guys, Meadow Green?) That paint was also used as a primer for other colors.
Nice truck!
Old 08-31-2012, 03:49 PM
thundersnow70's Avatar
thundersnow70
thundersnow70 is offline
welcome to the club tim! i am always glad to see another old factory 4x4 being saved and loved on. i am single handedly trying to save every one that i find. glad you are helping. dont get me wrong guys.............nothin against a 2wd fridge, i would just rather have all the wheels pulling. looks like a pretty straight truck and as already stated repair panels should be easy for you as it is a f100. if you have a few weeks to wait i should be getting my hands on a factory 223 oil bath air cleaner for that one barrel carb. just keep fixing bits and pieces as you drive and enjoy it and before you know it years will have passed and your wallet will be empty. plus you will have a truck few have and few have seen. keep in mind its 52 years old and you drove it home. there's alot of late model junk out there that cant do that! good luck and dont be afraid to ask stupid questions. i do!! these guys on fte are great!!
55fordcoe
Large Truck
01-17-2016 01:34 PM
Not a Mechanic
1947 and Older Ford Trucks
05-09-2013 07:14 AM
77ferd
10-14-2012 10:02 PM
jgc2521
General Automotive Discussion
11-10-2005 07:29 AM
Lwlandy
08-04-2005 09:26 PM
Quick Reply: New member, old truck
