Battery Relocation
What are you looking to accomplish by relocating the battery to the engine compartment? Most people want to move it out of there for a cleaner look under the hood. You could probably use a battery tray from a 48-52 V8, which sits on the right side frame rail next to the firewall. They're available in reproduction.
That is a good question. WHY would you want to move it into the engine compartment?! The stock location is great. It's out of the way and nice and low for a better center of gravity. If you REALLY have to move it somewhere, then go for behind the seat with two 6 volt optimas in series. That's what the hotrod guys do to keep their engine compartments looking good. Jag
Ditto what skuzzel_butt did except on the left side. Used a plastic tray out of a late model van - maybe Astro van - but one that was flat on the bottom - not contoured to fit it's original nook and cranny. Then I fabbed a L shaped angle iron bracket that bolted to the side of the radiator frame (officially called radiator Saddle). Turned out pretty good because the + terminal faces a wide open area between the radiator and the AC compressor and the - terminal faces the left end of the radiator. I would not like to have the + terminal close to anything it might contact and ground out.
I forget what the tray can out of. And yes, the battery is tipped off to the side.
An older shot from the side before the fender was installed.
82_F100_300Six
04-27-2018 07:58 PM
bobwires
09-14-2010 11:20 PM
turnrjr
10-06-2009 07:11 PM
