Fuel transferring from rear to front
Old 08-28-2012, 05:33 PM
foolgator1's Avatar
foolgator1
foolgator1 is offline
I know this has been discussed ad nauseum but here I go. 2 new motorcraft fuel pumps. complete assembly's. I have warrantied the front one twice thinking I was getting bad parts. I want to just install external fuel line check valves. Anyone know a good alternative to the Ford part that seems to be 120 bucks. Would I be wasting my time getting some from the junkyard. A lot of people mention this fix but I can't seem to find part numbers. The issue is what the heading states.
Old 08-28-2012, 05:43 PM
foolgator1's Avatar
foolgator1
VALVE - FUEL RETURN CHECK
Part NO.: F3TZ-9J274-A
This one is 90 plus shipping. was hoping for a cheap fix
Old 08-29-2012, 09:07 AM
subford's Avatar
subford
subford is offline
Take you FDM back and ask for a different brand.
One brand did leave the check valve out of some of the FDM.
Old 08-29-2012, 10:09 AM
92 Black Nite's Avatar
92 Black Nite
92 Black Nite is offline
This is exactly why I think FTE is the best. This is excellent tech. info. That gives everyone a heads-up when replacing one. I was fortunate that the one I bought had a check valve. The information members post here is Great
Subford, Your help is always appreciated. Thanks , '92
Old 08-29-2012, 01:08 PM
BuickBrian's Avatar
BuickBrian
BuickBrian is offline
Does your 1990 have the large high-pressure pumps in each tank, or the small pusher pumps in each tank with the high pressure pump mounted on the frame under the drivers feet? If the latter, your problem is in the pressure actuated tank switching valve. It is right under the drivers seat and has lines from both tanks connected to the inlet, and one set of lines going out to the engine. Looks like a filter canister, but there is no filter in it.
Old 08-29-2012, 02:09 PM
subford's Avatar
subford
subford is offline
A 1990 F-series had the pumps in the tank only. The E-series had the other system through 1991.
Old 08-29-2012, 04:38 PM
foolgator1's Avatar
foolgator1
Subford i am on my 3rd "Motorcraft" pump assemblie. I don't think I can try to warranty exchange again. Maybe I could call motorcraft. I assumed a new not rebuilt motorcraft pump assembly would be the correct one. Live and learn. (groan)
Brian I have the large pumps, no underframe mounted one.
Any recommendations for a check valve or bite the bullet and buy new ford ones?
RadioControlGuy85
08-06-2017 05:39 PM
1993 ford
24
06-25-2017 11:22 PM
BBrad
09-13-2004 10:27 PM
Quick Reply: Fuel transferring from rear to front
