Squeak/Chirp on takeoff (1996 Ford Ranger 2.3L)
Old 08-27-2012, 11:39 PM
FLhunter's Avatar
FLhunter
FLhunter is offline
There's a small but clearly audible chirping/squeak coming from my truck whenever I pull out. It goes away after the truck gets hot, but for the first 10 minutes or so, it squeaks only when moving. Not at idle. It is worse at low RPM's in 1st gear. And it's particularly bad in the mornings. Any suggestions? I was thinking it is something in the idler pulley or the belt tensioner.
Old 08-28-2012, 08:07 AM
Furyus1's Avatar
Furyus1
Furyus1 is offline
Sounds like brakes to me - when you first pull out, roll the window down and stick your head out to listen for the sound - if it sounds like it's coming from the wheels, it's probably the brakes...
Old 08-28-2012, 10:42 AM
FLhunter's Avatar
FLhunter
FLhunter is offline
It isn't the brakes. It's somewhere dealing with the serpentine I'm pretty sure. I can spray WD40 on the Idler Pulley and it stops until the next morning. Idler puller need to be replaced?
Old 08-28-2012, 12:18 PM
reddog99's Avatar
reddog99
reddog99 is offline
Is the noise cyclical, like something in the drivetrain would be, or more random as suspension?
When was the last time you greased the front wheel bearings?
The U-joints or ball joints are another possibility.
Old 08-28-2012, 01:43 PM
FLhunter's Avatar
FLhunter
FLhunter is offline
Like I said. It sounds like it's coming from a pulley in the belt since it's not always doing it. Not from under the truck but from the engine bay.
Old 08-28-2012, 02:26 PM
Furyus1's Avatar
Furyus1
Furyus1 is offline
It could very well be the idler if you can quiet it down with WD-40. They're not that expensive - I want to say they are in the $30 range - not difficult to replace, either.
Old 08-29-2012, 08:14 AM
97ranger xlt's Avatar
97ranger xlt
97ranger xlt is offline
if it is the original idler pulley (metal) you can remove it and re grease the bearing.
Old 09-02-2012, 01:07 PM
Jefahfah's Avatar
Jefahfah
Jefahfah is offline
I have something similar. A squeak that sounds more like it is coming from the back of the truck. 96 Ranger xlt 2.3L. But it only happens when the truck is in gear and I am giving it gas. I can push the clutch in and coast and it stops immediately. Get up to 30 mph and it goes away.
ford2002f150
1997 - 2003 F150
05-16-2017 10:44 PM
mustang_309
07-27-2015 07:17 AM
Jimmy Dean
1997 - 2003 F150
07-31-2007 11:20 AM
nitrobologna
1997-2006 Expedition & Navigator
07-16-2003 05:21 AM
Quick Reply: Squeak/Chirp on takeoff (1996 Ford Ranger 2.3L)
