Dodge dakota chassis swap.
Old 08-25-2012, 02:58 PM
troy77's Avatar
troy77
troy77 is offline
Has any one used a dodge Dakota chassis and put there body on it. Or is there a link to doing this. I have access to a 2005 chassis with everything on it including motor and tranny. And complete dash and controls. Is it possible to put my 77 ford body onto it and how hard would it be. Any help would be great thanks.
Old 08-25-2012, 04:32 PM
jim collins's Avatar
jim collins
jim collins is offline
Why ?____ If you want a dodge just buy one and not ruin a good Ford. Or at least use a later Ford chassis if you want things updated.__
Old 08-25-2012, 09:15 PM
troy77's Avatar
troy77
troy77 is offline
The only reason I was going to try the dodge is because I can get a great deal on a 05 chassis with the motor and tranny with less then 15000 miles on it. With the complete dash intact. My 77 is a long bed and I want to convert to a short bed. Thought it would be easier using the new chassis with all the modern equipment for handling. I had heard that you could use the dakota chassis as a swap. With little fab. Do disrespect to fords. Any help would be appreciated.
Old 08-25-2012, 10:02 PM
troy77's Avatar
troy77
troy77 is offline
No disrespect. Not do. Whoops. 😁
Old 08-25-2012, 10:37 PM
Thunderjet4x4's Avatar
Thunderjet4x4
Thunderjet4x4 is offline
Might be wiser to just do the crown vic suspension swap, then drop in a 5.4 3v, or a 5.0 coyote or just freshen up the original engine.
I don't think the dakota chassis would be much better than what you have, except its newer.
Old 08-25-2012, 10:41 PM
husker77's Avatar
husker77
husker77 is offline
What are your goals? Doesn't seem like all that good of a swap candidate to me.
Old 08-27-2012, 05:51 PM
troy77's Avatar
troy77
troy77 is offline
I think your right. I think I'm gonna pass on it for now. Maybe try out the crown Vic front end. Any good links to that process?
Old 08-27-2012, 06:04 PM
keiths78f150's Avatar
keiths78f150
keiths78f150 is offline
Convert a long bed to a short bed? Do you plan on buying a short bed or sectioning out the bed and cutting it up?
Old 08-27-2012, 08:41 PM
HotrodSmurf's Avatar
HotrodSmurf
HotrodSmurf is offline
Sure, if you want real pretty nightmare. I'm planning on getting my bare bones 76 running to be my dd even though it was intended as a project because I HATE my grand cherokee, dakotas are even worse.
Old 08-27-2012, 08:49 PM
husker77's Avatar
husker77
husker77 is offline
Old 08-29-2012, 02:29 PM
troy77's Avatar
troy77
troy77 is offline
Thanks for all the replies. I really appreciate it. Yes I had planned on sectioning the bed also. I've seen that done many times. Shortbeds are hard to find, and if you do find one they usually want a pretty Pennie for it.
Old 08-29-2012, 02:34 PM
troy77's Avatar
troy77
troy77 is offline
Also the motor that I have in it is a 351 modified. It didn't come with a rear oil dipstick. Just a front one on the passenger side front of block. But I don't think it reads correct. I've put 6 quarts of oil in it and it doesn't register on the stick. I'm also having a hell of a time trying to find a plug to fit in the rear oil dipstick hole. It is threaded bit nothing I buy fits. Anyone know the size of it. The original rear dipstick isn't available anymore from ford. Might try looking at the junkyard.
Old 08-29-2012, 03:40 PM
keiths78f150
By sectioning the bed, I believe you are going to cause yourself quite a headache. Making it look good will require a TON of body work. Just shell out the extra money for the short bed. I think you will be happy you did.
Old 08-29-2012, 03:43 PM
JB78f150's Avatar
JB78f150
JB78f150 is offline
If you know what you are doing then it will look fine. It will just take some work.
Shmit90051
31
05-22-2019 09:11 PM
plaisance
06-25-2017 07:43 AM
TxRebel89
10-25-2015 11:48 AM
Classic_Fummins
Engine Swaps
09-13-2014 08:00 PM
CharGriller
28
01-07-2009 02:12 AM
Quick Reply: Dodge dakota chassis swap.
