Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 08-18-2012, 09:48 PM
tomshelby's Avatar
tomshelby tomshelby is offline
Garage is empty, add now
tomshelby is starting off with a positive reputation.
PATS, dead odometer and scanner not connecting
I have done alot of searching and reading about the PATS sytem and the blanked odometer.
Ill start with some useful info on my project. I stripped a 2000 lightning and have installed the complete running gear, electronics and wiring into a 56 f100 (pics at shelbycars.blogspot.com ).
Click the image to open in full size.
The project has been on stand-by for about 4 years until I started working on it again about a month ago. Ive spent the last few weeks installing the harness, electronics etc. Finally friday I installed a battery and turned the key to see what would happen.
first, I noticed the odometer showed "-------". I have read the threads about the blank odometer so I will repair that monday when I get to the shop.
second, the security light was flashing and would not engage the starter. (I do have the coded key and transceiver ring in the system from the donor)
third, I tried for several minutes to connect my innova scanner and it would not link to the vehicle. Finally it linked and I noticed that the odometer was working. Before I was able to pull the codes I lost the connection.
My questions are
1 Does the odometer connection affect the scanner? or just coincidence?
2 Does the odometer connection affect the PATS?
3 Does the key, inst cluster have to be re-programmed due to being disconnected for 4 yrs?
4 Does the transceiver ring have to be programed to the system? I assume it just passes the info to the cluster and woud not need programming
I know that the instrument cluster is a key part of PATS system but not sure about the scanner comm port.
Im not looking for opinions or guesses or "I would think's." Only experienced individuals who have a very good understanding of the systems.
I appologize for my spelling, missing letters and extra letters. Smashed my finger and typing sucks with a huge bandage
  #2 (permalink)
Old 08-19-2012, 06:22 AM
projectSHO89 projectSHO89 is offline
projectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to allprojectSHO89 is a name known to all
Your symptoms are of a PCM that is not being properly powered. An additional data point would be to observe if the MIL is coming on during initial prove-out.
If the PCM does not receive proper power at start-up, the usual set of observations would be 1) No MIL, 2) Odometer "------", 3) No PATS prove-out, 4) No OBDII connection, and 5) No start.
If this were still in the original vehicle, I'd suggest focusing on the PCM Power Relay.
__________________
2001 F250 SD V10 4x4
HVAC FAQs: http://www.ford-trucks.com/forums/75...xpedition.html
Owner's manuals: https://www.fleet.ford.com/maintenan...ls/default.asp
It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.” - Mark Twain
  #3 (permalink)
Old 08-19-2012, 08:32 AM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed is gaining momentum as a positive member of FTE.70f100longbed is gaining momentum as a positive member of FTE.
+1 on the PCM relay. Seen it many times. If the cluster cant talk to the PCM then you have those symptoms. Either the PCM isn't getting power or ground, or you have a network concern.
__________________
Ford senior master tech
Every 5.4 3V owner should have Lisle tool #65600
  #4 (permalink)
Old 08-19-2012, 09:18 AM
tomshelby's Avatar
Thanks both of you. I am running the complete lightning harness with all relays etc so ill look into the relays, grounds etc. Thanks again
  #5 (permalink)
Old 08-19-2012, 12:13 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
1999 Ford F-250
My Garage
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Sorry Tom, I can't help because I suck at anything electronic/electrical but I had to post up and tell you I think your project is baddass!
Stewart
__________________
The Brotherhood of FTE <-click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
1999 PSD F250 SC 4x4: 38R, Stage 2's, T-500, JW trans, Live Tuned, lotsa Riffraff stuff
2000 PSD Excursion 4x4: 38R, JW trans, F5, MBRP, AFE, OBA and Pre-Pump, V & B codes
Never Fry Bacon NAKED!
  #6 (permalink)
Old 09-07-2012, 11:16 AM
Poolshark1321 Poolshark1321 is offline
Poolshark1321 is starting off with a positive reputation.
This is a great idea, thanks for sharing... loving the way that 56 looks man keep up the good work!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
