Rebuilding my 6.9 n/a...need more advice please
Ok guys, after the first round of good advice from everybody I did some more research and testing.
First...Engine starts fast...very little smoke of any kind at all operating temps from cold to warmed up...little bit of black smoke when punching it.
Second...Engine uses about a quart of oil every other fill-up...Oil analysis came back good...
Third...Warm engine compression test...lowest was 375 at #2 & #6 cylinders...highest was 425 on all other cylinders...
Fourth...Engine does not have any "knocks" top or bottom...
So, I think I will chance it and not rebuild, but instead install a new banks sidewinder turbo. I will also have heads done with high temp valves and 7.3 turbo'd rockers and head studs and new head gaskets as well as BB injectors and new IP.
Questions? Which head studs and head gaskets should I use? Maybe copper gaskets???
Also, should I use 7.3 turbo'd exhaust manifolds? If so, should I polish the ports?
The turbo as you know is wastegated and the kit came with exhaust system.
What am I forgetting? More advice please and any other thoughts will be appreciated....
BeerCan500
BeerCan500
BeerCan500
BeerCan500
BeerCan500
08-13-2012 03:04 PM
BeerCan500
08-09-2012 12:51 AM
