Shocks For Leveling Kit on 1999 F250 SD 2WD
I am currently purchasing the components for a leveling kit on my 1999 F250 SD 2WD. I got the 2" aluminum spacers and now I am working on the shocks for it. I will be using a shock conversion that will use the eye ring bushing rather than the OE stud mount.
My question is...What length shocks should I got with? 0"-2" or 2"-4" of lift? And any recommendations on the brand and style of shock would be greatly appreciated! Thanks in advance!
What eye ring bushing conversion kit are you using? Depending on how and where it mounts will determine what length shock you need.
Plus, I would be interested in seeing the option. I ended up welding an extension onto my stud to get a longer shock for my leveling kit. The shocks I found for a 2" lift had a ride quality that was much less than desirable.
The problem is going to be finding a shock with those dimensions, that has a round eye top and bottom, and offers the same amount of travel. I hope you find something. I didn't have any luck when I searched, which is why I ended up welding the extensions on my shock studs and used some spacers to make it all fit right.
That's what I was thinking. I figured that should just go with the 0"-2" length because with the addition of the shock conversion, it would be as the the shock was still at stock length. Just wanted to make I had the right idea. I was thinking that a Rancho RS9000XL might work for my application....
1999-2004 Ford F250 Superduty 4wd Rancho Leveling System Excl. Chassis Cab or AWD (Lifted 2 1/2" Front, NA Rear) - Rancho RS9000XL Shock (Front)
1999-2004 Ford F250 Superduty 4wd Rancho Leveling System Excl. Chassis Cab or AWD (Lifted 2 1/2" Front, NA Rear) - Rancho RS9000XL Shock (Front) - RS999264 | $105.99
No, that won't work. You can't use a 4wd shock on a 2wd truck. The 4wd mount bolts to the frame and extends above the frame so they're not even close to being the same size.
The 2wd shock has a compressed length around 10.3" and a fully extended length around 15.3". That gives you about 5" of travel.
The 4wd shock for the same year model, or more specifically, your Rancho Shock that you mention has limits of
Rancho RS999264 shock. Compressed length: 15.625" Extended length: 24.375"
Travel: 8.750"
So that means by the time you install the eye mount, you cannot even compress the 4wd shock enough to install it, much less have any travel for absorbing any shock.
Travel: 8.750"
If you want to look into shocks, look at this site Rancho, Bilstein, Pro Comp and Fabtech Shocks
They are nice enough to give you dimensions on different shocks if you think you find the correct model number. You can also look around here since Rancho is a sponsor here. They have someone who has been quite helpful in the past trying to help find shocks for odd applications.
He helped me find a longer shock that would possibly work with the standard mounting configuration, but the shock proved to be too long for the rough roads I travel. Bottoming the shocks out proved to be the end of them.
Here's some reading for you on my latest attempt in finding the perfect shock. https://www.ford-trucks.com/forums/1...ck-travel.html
Many others have had no issues at all just running the stock 2wd front shock. As usual, I wasn't one of the lucky ones.
saltamontes
1999 to 2016 Super Duty
03-03-2009 03:43 PM
