2011 and up Sterling 10.5 Gears
Looks like the 2011 and up has the Sterling 10.5 with a new 37 spline rear and since its so new the only gear options that are out there match the current stock options up to 4.30. Anyone catch any wind on when and who will come out with aftermarket gears for this so I can re-gear up to 5.13 or so. Thx.
I hate to wake a dead horse but has anyone found a soultion to this? As the OP states the deepest you can get for the 37 spline is the 4.30 offered from the factory. I'm interested in running the older style gear set (31 spline) because i need deeper than 4.30. The question would be, is it possible to use the the 31 spline pinion in the new housing with the correct bearing and flange? The carrier issues are known and covered with what bearings are needed. The gear vendors don't know and are no help. I can't be the 1st one to possibly try this.
highoctane74
02-28-2012 02:05 PM
stangbanger
04-06-2009 02:42 PM
Glenn O
10-26-2008 07:04 PM
