Sponsored by: Real Truck
reusing rear gear set
Old Jan 20, 2014 | 01:11 PM
SuperDutyScaler's Avatar
SuperDutyScaler
with all the threads about LS vs lockers lately ive decide that its time for me to ditch my stock LS. About four years ago i spent 2K on OEM 4.30 gears for my truck and the shop that did the work said i can reuse the rear gears if i havent beat on them???? I dont do burnouts and i never go from R to D without coming to a complete stop in my truck so i cant see why my 4.30 gears would be WRECKED right? Just trying to save myself $200 for a second set of 4.30 gears you know.....
Old Jan 20, 2014 | 01:18 PM
MisterCMK's Avatar
MisterCMK
I see no point in replacing the gear set if they aren't sharp or obviously worn.
Sent from my Telegraph using IB AutoGroup
Old Jan 20, 2014 | 01:25 PM
SuperDutyScaler
i had the gear swap done then about five months lately i installed the 08 up aluminum diff cover and installed Mobil1 synthetic and i have about 45-50k on the new 4.30 gears with no heavy towing like i use to do with the stock 3.73 gears
Old Jan 20, 2014 | 05:45 PM
Leon82's Avatar
Leon82
They may need move some shims for the carrier to get the same backlash as before. since you are not removing the pinion the depth will not have to be reset.
Old Jan 24, 2014 | 11:22 AM
SuperDutyScaler
the guy i went to was a Ford tech for years, then he retired and opened his own little shop. On my bill he has 10 thousands gap and he wrote 8-12 is spec...... i talked to him and hes going to give me a price for a Detroit locker, Detroit Truetrac, and a ARB air locker minus the air pump ill install that
Old Jan 24, 2014 | 02:13 PM
Diamnd1's Avatar
Diamnd1
My experience in reusing gears is after reinstall they whine. Reason being is when they are new there is no wear pattern. Thus, quiet after break in. Even if you set the tolerances correct after reinstall, the original wear between pinion gear and ring gear never matches like before. Nothing wrong with reusing, just be aware of possible noise from the gears. Especially if you have hauled or towed heavy loads on those gears, the wear will be more significant than just a daily driver. I would opt for new gears just to avoid the headache, but it isn't my money to throw around.
Old Jan 24, 2014 | 02:44 PM
EXv10's Avatar
EXv10
I rebuilt hundreds of rear ends and those gears are hard as a rock, even after towing and abusing. Definitely use them again. The specs aren't nearly as important as getting the pattern right with red lead, Prussian blue, or your marking material of choice. Don't waste a good set of gears! And they will be quiet if set up right.
Old Jan 24, 2014 | 03:26 PM
jesse5's Avatar
jesse5
If they are OEM I would probably give it a try and put the money toward the ARB selectable. Then again if you can get OEM for $200 you may want to consider it as reassembly would cost more than that. Good fortune.
Old Jan 24, 2014 | 03:37 PM
EXv10's Avatar
EXv10
Aftermarket gears can be re-used also. People don't realize how hard those things are and nothing can touch them...............unless you run low on oil.
Old Jan 24, 2014 | 04:00 PM
jesse5's Avatar
jesse5
If I could get OEM for $200 I would not consider aftermarket in the first place. The OEM's are so much easier to set-up as sometimes you can use the original shim measurements as you already know.
Old Jan 24, 2014 | 04:44 PM
Tom's Avatar
Tom
I agree with Brent...why in the world would you throw away good gears? Most gear sets will last FOREVER without making noise as long as they are setup correctly, regardless of the type of oil or use.
Old Jan 24, 2014 | 05:32 PM
EXv10's Avatar
EXv10
Even drag racing won't wear them out, many people have hundreds of runs on the same gear set with 5-600+ HP. I ran my fast 55 Chevy for 10 years with the same rear end.
Old Jan 24, 2014 | 08:42 PM
Diamnd1's Avatar
Diamnd1
I do agree, however if the setup is not correct or the wear pattern is not close, they will make noise. Just giving you a heads up.
Old Jan 24, 2014 | 09:09 PM
EXv10's Avatar
EXv10
What I said.............heads up.....lol
Old Jan 25, 2014 | 07:53 AM
02TB250's Avatar
02TB250
Just as food for thought.. I've also been looking into this as the factory LS is odd, and engages in a really inconsistent manner.
While looking I've seen many people run TT front and rear (mainly jeeps) but when looking for that, its almost all front differentials are 4.10.and numerically lower or 4.56 and numerically higher gears. But nothing works with 4.30s that I've seen. So if you eventually want to lock the front you might want to consider that.
Sent from my Galaxy using IB AutoGroup
