ABS light on?!
I have been having similar issues, but mine are intermittent. I can start the truck and I will stay on for a bit and go off, or it will stay on. If that is the case, I shut it back down and the light will cycle normally. I probably need to check all my sensors and see if I have one going out. Question is: where are the sensors located?
on
1 Post
When I had this problem, it turned out to be a broken ABS sensor wire going to the left front hub. The plastic retainer broke and let the tire rub the wire in two. I spliced it with a good weather proff splice and replaced the retainer with a big tie wrap. It could be other things like VSS etc. but check your wires too.
I had the same issue with my 01 when the batteries got low. I put my AE on it and it said "ABS Voltage low" I reset the light with the AE and have never had a problem since. I guess if the battery voltage drop below a certain value, it flags a hard code. If you know someone with the Auto Enginuity program, they can reset it for you. Otherwise you'll probably have to take it to a shop.
As far as this being a critical issue ... it isn't. If the ABS light is on, you don't have ABS, but you will have fully functional brakes. The only difference is that the brakes will not pulse during a panic stop.
Braking effort and response will be the same no matter what, except in a panic stop. If you cannot get the ABS problem figured out before needing it for a trip, drive it anyway, just be aware of it. Basically, your braking system will be as if you have regular brakes.
paul1910
01-27-2008 08:30 AM
