Leaking HPOP
Leaking HPOP
My truck has been leaving it's mark in my driveway for a while now.
Big trip coming up in 6 weeks. So I started to clean and dig, found out the HPOP is leaking against the engine. Pretty sure it's the gasket against the block that is leaking. Question is , should I rebuild the entire pump while it's out ? And what else should be done while I have the pump out ? I plan on buying the parts at dieselorings.com
Truck is an excursion 7.3 with 149,000 miles on it
Thanks for any tips
Thanks for any tips
Thanks for any tips
Thanks for any tips
Backing up the bus a bit... the EBP sensor is on a plate in front of the HPOP. If you turn a wrench on this without a wrench on the other side to counter the force, you will bend the plate. The plate does not have an O-ring, it is RTV'd in place - I'd first double-check to make sure this isn't your culprit.
[INSTRUCTIONS]
[INSTRUCTIONS]
Nope, the plate he's referring to is in front of the HPOP reservoir and slightly below it. Its a plate with an attached bracket that is supports the EBP sensor, with the EBP tube running below it down the front of the engine.
X2 on rebuilding the entire HPOP while you've got it off. Unless you've already done it, go ahead and rebuild the fuel bowl too...the entire kit is pretty inexpensive from dieselorings and you're already going to have the whole fuel bowl pulled. It shouldn't take you more than an extra hour of work. And that's some major insurance against future leaks, because all those seals will end up leaking eventually.
I'm not saying that is your issue, I just mentioned it was worth a look because it covers the HPOP drive - plenty of oil splashing around in there. One member had an oil leak and discovered his was bent out. His fix was to remove it, straighten it, and re-seal it - problem solved.
Sometimes a member will say I have XYZ problem and many of us who have run into the same problem suggest the same cure they used. Issues that pop up like prairie dogs frequently have more than one possible answer, so I just do my thing of offering up the alternative possibilities.
